Barry_Green
Moderator
It would, I'm just saying that it won't happen because the DVCPRO-HD compression isn't scalable. With AVC they could do it...
And budgets that big filmmakers are used to now will NEVER happen again. They really won't. The NY times did a huge article about how studios are aquiring financing with other studios, but are increasinly turning to movie-investment funds (like mutual funds for hollywood), the fund managers are pushing for lower budgets. That is #1 on their agenda.
I would expect it to as well, but let's wait and see before making blanket proclamations like that, because you may end up being surprised.David Newman said:SI-2K will easily out perform a hydra modified HVX.
Huh? Only in black and white! Yes it has more pixels, but they need to be overlapped or else you're only looking at a monochrome image. If you stripped out the bayer filter then yes you'd get a 1920x1080 image at full resolution, but because there's a bayer filter in place you have to combine pixels (in a process that's remarkably similar to pixel shift) in order to get color from the sensor.The single sensor doesn't have overlaped pixels so it can resolve a higher resolution image
Again, that remains to be seen. If I'm reading the spec sheet properly, the SI-2K has a bayer'ed 1920x1080 single sensor, which means its actual pixel count is 960x540 blue and 960x540 red, and 960x1080 green, with 5-micron pixels. The HVX has 960x540 blue and 960x540 red and 960x540 green, with 5-micron pixels. So yes the green is higher, but the HVX also uses vertical spatial offset (something that AFAIK has never been done before) so ... it's too early to tell, but I wouldn't be surprised if the Hydra results are *extremely* competitive with the SI-2K. Soon enough the results will speak for themselves.whereas pixel shift can't go as far. 3 x 1k x 0.5k pixels is less than one 2k x 1k sensor, so even if pixel-shift was equivalent, it couldn't match the SI-2K.
Yeah, I just misunderstood. I'm not used to hearing people talk about pixel size instead of chip size or resolution round these parts. Maybe I just don't pay enough attention. Hehe.arrestthisman said:Yes aculag, that's basically what I said. I was speaking about the individual pixels NOT the chip size or total resolution.
Then what are you doing here?ksteiger said:Unless there is a new HVX200 model that provides a perfect script and actors without egos, I am perfectly happy NOW ! Sometimes I think some people on this forum spend too much time fantasising and not enough time shooting.
Carpe Diem.
Mediacre said:Yes, I know RAW is a big improvement, but that is basically a color improvement. I was talking resolution. Do you guys really think the HVX200 lens is good enough for 2K? I can't see that when true real HD lenses cost 4 times more than the HVX itself. If the lens can't record it it doesn't matter what the hydra pixel shift does.
I'm not sure the bit increase alone is worth the mod unless for effects. That would be most useful for effects work. To be an all around worthwhile mod it would have to deliver the promised 2k resolution. But I don't see how if it has to go through the fixed HVX lens. The SI2K can use Digiprimes if you want. That should beat the HVX lens by light years. No arguing in my opinion. No way hydra will come close to the SI2K IMO. Not ditching Juan's efforts. It's just logic.
Of course a DigiPrime will beat the HVX lens (or, at least, it certainly should).But I don't see how if it has to go through the fixed HVX lens.
