If you need to go on a crane, shoot P2. Expensive, but your best option.
Because no one needs DVCPRO HD on small DV tape. Not my words.Today I got my HVX200A and after I tried the Record options I could see that 1080 on tape is missing. Why is that?
I'm not sure that flatly characterizing P2 as "expensive" is all that fair considering what the format is - a very compact, very high-speed solid state memory card that is reusable thousands of times over. And it has been declining in cost rapidly, particularly most recently. I know you know all of this as well as anyone Perrone, but perhaps slightly moderated language would do it more justice.
My $.02
Why should I buy a P2 card instead of FireStore? FS has more than 100GB and P2 16 or 32. Is it impossible to use FS with crane?
that is typical, new-user, short-sighted logic. focusing only on your wallet and NOT long term value/usability. there are situations where firestores arent well suited. and situations where a pair of P2 cards wont be sufficient. BUT no. i cant see ANY reason why crane use would pose a problem for a firestore - unless you were doing some insanely fast crane whips. which would be unwatchable anyway...Why should I buy a P2 card instead of FireStore? FS has more than 100GB and P2 16 or 32. Is it impossible to use FS with crane?
id aggressively argue that logic. typical crane moves arent going to subject a drive mechanism to undue stress. and you can always run a long enough firewire cable to circumvent such issues IF they did exist...The firestore is hard drive. At least the one compatible with Panasonic's format. Not the best idea to try recording onto a hard drive while you swing it around in the air on the end of a crane.
Sorry, however, when a format costs $1000 per hour for recording, I consider that "expensive".
I fI decide to use P2 cards, do I need an extra Card reader too for Laptop (Not apple) or can I use it without buying anything extra?
It would cost that much if you only used it once.
Depends on the slots in the laptop.
Search around the forum some; the answers to all of this will be here.![]()
