HVX200A Creeping Zoom
Alex412
I just purchased a used HVX200A and have come across a slight issue when zooming. After I release the zoom toggle the camera continues to zoom in at a very slow zoom rate. You can stop the motion by pushing the toggle to zoom out just slightly and it will lock in.
Has anyone else had this problem and if so an easy fix??
Best Regards,
Alex
if its anything like the dvx, there should be a little switch below the lens, and if switch it on then off it should fix the problem.
