been having issues with the firewire port on my HVX. the headphone jack is goofy too, so i think that whole section of the camera is failing. needless to say, i switched over to using USB to transfer off the p2s.
all is well, in terms of connecting and transferring. in fact, i am getting much better transfer speeds over usb. may have to do with failing firewire port...
my PROBLEM is that i can't seem to safely disconnect the camera from the computer after transferring. ejecting each volume from clears it from the finder , but the "CONNECT" prompt never switches over to "DISCONNECT" on the HVX. this means it is still active, and not safe to disconnect, correct?
the only way i have found to make it say "disconnect" is to completely turn off the computer. this is very inconvenient in a field shooting environment. anyone experience this problem and know a solution?
For the record, i am using a late 2009 macbook pro. i just read something about HVX USB incompatabilities with mac. this may be what they're talking about?
thanks for your help
-dv
-dv
