<br />Cards are better for many reasons, so you if you need them, you should get them. But if you can't, then OnLocation works just fine. It just doesn't give you all the advantages the cards do.<br />
<br />
Of course, many people would advocate shooting using OnLocation even if you're recording to cards for the fantastic scopes and tools it has.
I've done quite a bit of recording of multi-hour seminars using an HVX-200 and ScopeBox. It saves the files in the native DVCPROHD codec with all audio channels in a QuickTime wrapper, ready to drop into Final Cut. Two things to watch out for though: I've had audio-sync issues on long recordings where the audio is about a second off, easy to fix and it doesn't drift over time. Also, if the recording is critical you may want to simultaneously record to P2 as a backup because I've had corrupted files on rare occasions under certain conditions (don't try recording to a slow USB drive!). This shouldn't happen anymore in v3.When I record directly to a laptop via OnLocation...it records, somehow, a diff. codec or something that it would on the card.
