I'm considering getting an HVX200 for a feature film shoot in July/August, and this forum's been a great source of info on it. I've shot 16mm film and DV (Canon XL1, GL1, and Sony F100) for a few features, and it's time to make the jump to HD.
I've got a few questions about it, if anyone could help.
Can I reliably rack focus with it?
Can footage from P2 cards be transferred to a hard drive using the PC card slot on an original model 15" PowerBook G4 400mhz (barely fast enough to edit standard DV in Final Cut Pro, but not fast enough to capture footage without dropping frames)? We've got newer laptops, but none with PC Card slots. If it just mounts like a hard drive and isn't speed sensitive, there shouldn't be a problem, but you never know.
If I shoot 1080p/24 for most footage and 720p for slow motion shots, how easily will the two edit together? Or should I stick to 720p for the whole production if I want to overcrank some shots?
Any recommendations for a good, cheap on-set monitor for checking focus? (Rather constrained budget.)
Thanks!
Thanks!
