dustinsleeping
Hello
I am new here and this place is great. So much info.
Anyway....
I have Avid Xpress pro HD 5.2.1 and my issue is this...
I am shooting a short film this weekend using an HVX200 w/ the P2 Store. I will be dumping the footage to am external hard drive on the set using a Dell laptop and a G-Raid 500gb Hard Drive. I will then bring the hard drive back to my Avid Xpress Pro HD system (PC) and edit.
But...
I am having the same problem as a lot of people...I can't get the Avid to see the MXF files (except when reading directly from the P2 Store...then it is fine). I shot some test footage and I did the whole Avid MediaFiles folder bit (as descibed in the 1st post on this thread) and nothing.
The folder I made looks like this in my computer...
E:\Avid MediaFiles\MXF\1
Is it the direction of the slashes that is causing the problem? Should it look like this...
E:/Avid MediaFiles/MXF/1
...and if so how do I cange them to look that way?
I had to make the folder myself. There was a folders called Avid_MediaFiles. I used that and took out the _ Then I moved it from the C Drive to the E Drive (its a bigger drive).
Also...
I know I more than likely wont get this figured out by tomorrow (when I start filming) so should I be worried about offloading all of our P2 cards to hard drives and hoping that later on I can read the files off of the hard drives and put them into Xpress Pro? I know I will transfer all of the files from the cards as we go (Audio, Video, Clips, etc). Will I be OK?
Any help or advice would be totally appreciated.
Thank You. :dankk2:
Dustin Lane
Anyway....
But...
Also...
Thank You. :dankk2:
Dustin Lane
