HVX200 is great, but I still need more sensitivity!
jrv3034 said:
Why do you need 2 8GB P2 cards? Get the $5500 HVX and one firestore for a total of $7500. Add some batteries for $200, not $400. Maybe get the Cinemek G35 adapter for $1300, and rent some lenses. Shouldn't be more than $10K total.
Again, all good suggestions, which only seems to make the decision that much more difficult. I just know, once I get the HVX200, I won't be able to resist buying all kinds of expensive crap for it to "dress it up." For whatever reason, it's irresistable not to. Matte boxes, follow focus, etc. which I wouldn't necessarily need/want for the full-sized camera (plus, I already have a lot of broadcast-camera type accessories).
Policar said:
Sequences of Collateral were shot with +9 to +12db of gain, with the cinematographer freaking out over how bad everything looked.
I can imagine how he felt!
Policar said:
If you want to use a 35mm adapter and shoot at night, you're crazy, too.
I know. That's the problem, I just know that's just totally not going to work.
Policar said:
Also, does the Sony lose sensetivity in progressive scan?
Don't know. I assume it does. Not to argue with you, but to compare the DVX100's claimed f/11 sensitivity to a 2/3" broadcast camera's f/11 sensitivity spec just doesn't hold water. Broadcast f/11 cameras have almost ZERO noise at 0dB. My DVX100 is super noisy at 0dB. There's no comparison. The HVX200, on the other hand, was surprsingly QUIET! Very, very, very clean in 1080i at 0dB. It may well be quite usable at +9dB or maybe even +12dB. Gotta just wait and see, I guess.
All I'm saying man is don't give up on the HVX yet. Wait until it comes out first. Unless the footage you saw really didn't look that good...in the dark.[/QUOTE]
Why not shoot day for night set ups? Do you HAVE to shoot only at night?
LA has many large shadow areas created by the large buildings....also in the winter months when there are more clouds the afternoons can be fairly dark.
I'm not saying that you won't do well with the Sony...but there are ways to create
dark conditions without spending 18k on a camera.
If your exterior set ups are for brief shots like establishing shots, then could you shoot them on 16mm or s16 and then get them scanned?
Do your exterior shots have to include street lights that are lit?
The Sony cam is DV-CAM which is the same resolution as mini-DV, and 5:1:1
color?
Yes, even though it sounds like you're not expecting a lot for low light performance, please wait and see.
I realize it's only a 1/3 cam, but we've heard
from those who have seen it and said what they saw looked clean.
I realize the footage seen was probably not in low light conditions.
It won't be long now.
Steve
Steve
NBCshooter said:
I know. That's the problem, I just know that's just totally not going to work. guess.
As far as the Cinemek G35 losing light - I am told by jonathan that it will lose virtually no light. I KNOW it will be less than 1 stop, but he's told me that it will lose virtually no light.
In my very very unexperienced opinion - I think what jrv3034 said makes the most sense. Get the HVX with a firestore. The firestore compared to the P2 cards will hold much more data, it's much cheaper, and you can read off of it without having the camera on and with you. Plus it seems like an external hard drive SEEMS to me like it could be more sturdy, and potentially more reliable (it's not as new of a technology as P2, and it seems like it could have less potential bugs). I'd deffinetly suggest getting the Cinemek G35. It's an amazing product. Get a few nice battery backs, and you've got yourself a setup that most of us here would give up their first born child for.... well... maybe not to that extent. But you get the idea. It's HD, the light sensitivity isn't BAD at all, plus you've got quite a bit of extra cash in your pocket for lights, or anything else. I don't know........ Just another opinion... or.. an affirmation of jrv3034s opinion Good luck making your decision. I'm sure you'll be happy whatever you do. (you just might be happier with the HVX ) haha.. good luck
-Jeff Jassky
jrv3034 said:
SD on the big screen has it's days numbered.
It's time enough to stop with unworking and unpleasant videoish - and UGLY (uff!) - proposals... Finally, there is someone that comes with "the" greatest conclusion... :thumbup: :thumbup: :thumbup: :thumbsup: :thumbsup: :thumbsup: With the "film look" is the aesthetics that is on the table and not the reverse!
<PS> Sorry guys my non-tech parenthesis but "the life is two days" in my native language...and sometimes there's no time to anything else than the movies... [...but thx anyway for the opportunity as your common reader.]
Jonathan's already quoted figures which total up to about two stops (when everything is added up.) Unless you shoot with an f0.7 lens (and they do indeed exist!) it will lose light, and quite a bit.
First there's the fact that "wide open" is f2.0 instead of f1.6 (1.4-2.0 is a stop so this is about half a stop right here or more.)
Then there's the diffusion screen itself.
Then there's the achromat.
Then there's the lens (fastest you're going to realistically get is f1.4 which is more like t1.6.)
That's already more than two stops, easy.
FYI: Every front-mounted achromat I've ever used had a zero-stop loss. I don't know why, but front-mounted tele-adapters, wide-angle adapters, and achromatic diopters, for some reason don't steal any light! But the rest of your math sounds right . . . unfortunately.
But lemme get this straight . . . whatever the maximum aperture is on your 35mm still lens (e.g., f/1.4, f/2.0), you simply add that numeric "stop value" to your total "light loss" column in order to sum your aggregate light loss? So if I'm at a half-stop loss just from zooming the HVX' native lens in a bit, then I add another 2 stops if I slap an f/2.0 lens on top of that, right?
Nevertheless, the HVX200 is really just too good of a camera NOT to buy, for any reason. There's just so much potential for compositing, slow-motion photography, time-lapse photography, etc with the 4:2:2 100mbps signal. The camera really offers a lot of incredible capability for not an outrageous price. This really is a tough one.
Policar - Keep checking over the cinemek site (www.Cinemek.com) over the next week or two. There are some updates that will be made :) The production model will lose less than 1 stop of light according to Jons laatest updates. I'm not sure how much less, but it will be less than 1 stop. Check the latest topics on the Cinemek forum (www.Cinemek.com/forum).
-Jeff Jassky
I'm not. I'll probably end up getting the HVX200 anyway.
Well, uhhh, it just looked real dark. Hopefully the camera will withstand some gain-up.
Waaaay, not the same aesthetic. I'm all about the lighting of the shot. And yes, I have to shoot only at night.
RogerandOut said:
I'm not saying that you won't do well with the Sony...but there are ways to create dark conditions without spending 18k on a camera.
They dropped the price by $2,300 in the last two months . . . it's now only $15K with glass, bricks, and a charger (and a free camera bag)!
Thought about going all 16mm. Way too expensive. And mainly, I wouldn't be able to do as many takes for performance.
The more light sources in the shot, the better. Spielberg loves to do that (watch E.T., Close Encounters, etc.).
color?
Yup, I know. By the way, it's spelled "DVCAM" and "miniDV" and it's 4:1:1 sampling and 5:1 compression. But DVCAM, with a really good camera head (and the DSR450 is a REALLY good camera head), looks pretty doggone good. It's better than BetacamSP, and that's what I shoot on everyday for NBC. Thanks for your thoughts!
How about this NBC:
I'll buy the HVX. You be the cinematographer on my feature, which has several night scenes. By the end of the shoot, you'll know if you like it or not. You'll get experience with the camera you're unsure about, and I'll get your expertise, leaving me to direct and act (and write and produce and score and record the soundtrack.. oh god, I'm doomed)
Oh, that is if you can wait that long. I'm slated to shoot next fall. I forgot, you're kind of in a hurry, huh?
NBCshooter, you keep up the angst... it's strange, it's as if all my *potential* anxiety over the HVX has manifested itself in you and your indecision.
Maybe I'm at total peace over this as-yet-sight-unseen purchase *only* because you're not... and if your troubled soul was at ease, my mind wouldn't be...
:) :) :) Just jesting in good fun!
Still, I'm not trying to make a habit of shooting under street lights, and if I was, I'm pretty sure I wouldn't even be thinking HVX. I'd stay with rentals, and put my mind at ease with something with big old fat light absorbing chips...
Regards,
Jim Arthurs
"in 2/3" CCDs versus 1/3" CCDs the signal that enters the analog amplification stage is larger (for a given pixel size). For a camera with an identical number of pixels, the increase in size from 1/3" to 2/3" is 4:1 or 2 stops. This is because the area is the product of XY (where X is one axis and Y is the other)."
Sure?, a 4 times larger area gives 12 db more signal, but the noise generated also increases by 6db. Though alot depends on which part generates most noise, the ccd or the amplifier.
regarding the pixel count, when each pixel is split in two, noise increases (obviously.. though again much depends again on the latter stages), but all the extra noise is in the extra detail, so, when you 'blend' them together again later you end-up with the same picture? So I guess my point is, nothing is lost when doubling the pixel count. The extra noise is in the extra detail. Filter-out the detail and you have the same sensor again. (though I might be wrong here, obviously :) )
Hi, NBCshooter.
I have just started out a small production. I am also debating of buying a DSR450WSL now and adding a HVX200 later. I heard some good things about the DSR450WSL, especially, its latitude. However, this camera has no true 24p shooting. In other word, it shoots 60i and converts footages to 24p later to tape. Is this true?
Anyway, I am still interested in this camera. Please can you tell me where I can get that deal $15k with len and case? Thanks.
:beer:
Really? I shoot with DSR-570's and BetaSP 600's every day (different clients). The 600's look is absolutely stunning in their uncompressed, analog glory. The 570's are always harsh and garish in comparison. When I was shooting "Blind Date" a few years back, they went from Beta600s to 570s: I was quite upset. Even though my camera dropped 10lbs of weight, it wasn't worth it for the degradation of image and brutally blown highlights of 4:1:1 and 25mb/s. Color too: the run and gun of Dating shows means I was alway in mixed light: BetaSP handled it beautifully but the DVcam footage was always harsh in that regard too.
You're comparing different camera heads. In a side-by-side test (a few years ago), with a dockable camera head, recordings were compared from a DVCAM back and a PVV-1 Betacam back. The DVCAM footage had better chroma specs. The only way you can compare the encoding formats is to compare the signals coming from identical camera heads. A 570 is NOT a 600.
vandeha said:
However, this camera has no true 24p shooting. In other word, it shoots 60i and converts footages to 24p later to tape. Is this true? Anyway, I am still interested in this camera. Please can you tell me where I can get that deal $15k with lens and case? Thanks.
Try bhphoto.com and search for "DSR450." The listed price for the Sony V-mount kit is $16,200. Click on "e-mail me a better price" and, voila! It's $14,999.95. As far as I know, the 450 shoots true progressive in either standard or "PA-mode" (2-3-3-2) cadence, just like a DVX100. Like all 24P cameras (DVX100, SDX900), they shoot 24P and then convert it to 60i so it can record to a standard tape format. Sony calls it PsF (progressive segmented frame). It's the same term they use to describe the way the F900 acquires 24P and lays that to tape in 1080i.
Sounds to me like you're looking at the wrong half of the problem, or not telling the whole story. Your stated goal here is to shoot your feature, and nothing else. A $15,000 camera expense sounds pretty ridiculous for that purpose. So...
A: you're wasting a lot of money that COULD be spent permitting and lighting and getting things to actually look how they should, just so you can own a new toy at the end of the day.
B: this purchase is part of some comprehensive business plan that requires you to have a camera long after you're done shooting this movie.
If your feature is really your priority, and you have the finances to cover it, it seems like you need to reconsider your motives and make the movie look as good as it possibly can. Sounds like it's time to spend some time re-examining your script and working out a shooting schedule, rather than fretting about details of camera engineering.
