Spiraledit
I just recently got back from a HVX presentation at Resfest here in NYC. They had the camera out on display, along with 1080i footage shot with the camera playing on a monitor.
Then there was a presentation in the theater given by Jan Crittenden, where all aspects of the camera were talked about. Then they projected HVX footage ON THE BIG SCREEN. The footage was simple pans and zooms of a simple set filled with various objects such as a color chart, fruit, fabric with fine detail, etc... There was also some weird spinning object to show off the motion quality. I have to say, it looked REALLY nice projeced on such a large screen (I believe she said it was a DLP projector being used)
I also had the chance to pick up the camera and must say that it was a bit lighter (around 7lbs or so) than the bulldog-like look that the camera has.
It was so cool to be able to look at the camera display and see thumbnails of each shot the camera made. You can then scroll thru the selections and pick any shot for immediate playback, deletion or whatever.
I asked about the new Firestore device and what benefits P2 would have vs using that kind of capture solution. Apparently the main advantages to P2 would be all of the metadata would be there, whereas the firstore would obviously be capturing the footage only. Also, with the P2, if you shot at a variable frame rate, once on your NLE, there is no need for frame rate conversion, whereas there would be with capturing to the firestore. But it does seem very good to know that until P2 cards get a little cheaper, there is a relatively cheap way to shoot and store large amounts of DVCPRO HD footage.
It certainly got me excited about having one!
Bryan
Bryan
