HVX Varicam match
Shane
Here's a scene file that I wrote in the field to match my HVX to a Varicam in Doc setting. Try it out if you like.
Shane.
SCENE NAME :VARIC
00005000: 10 ; DETAIL LEVEL: 2
00005001: 13 ; V DETAIL LEVEL: 5
00005002: 11 ; DETAIL CORING : 3
00005003: 5 ; CHROMA LEVEL: -3
00005004: 8 ; CHROMA PHASE: 0
00005005: 12 ; COLOR TEMP: 4
00005006: 19 ; MASTER PED: 3
00005007: 6 ; A.IRIS LEVEL: -2
00005008: 1 ; NEWS GAMMA: OFF
00005009: 6 ; GAMMA : CINELIKE V
0000500A: 0 ; KNEE: AUTO
0000500B: 3 ; MATRIX: CINE-LIKE
0000500C: 1 ; SKIN TONE DTL : OFF
0000500D: 2 ; V DETAIL FREQ : THICK
0000500E: 1 ; OPERATION TYPE: FILM CAM
0000500F: 0 ; FRAME RATE: DEFAULT
00005010: BE026801 ; SYNCRO SCAN :
here's a screen grab recompressed in JPG format:
WOW!!!
Thanks...i cant wait to get a chance at trying this scene file out!
AWESOME!
btw: is that a commercial or something you shot?
Cynic821 said:
WOW!!!
AWESOME!
It's for a pbs show that I shot B camera on. The producers were looking at the viability of shooting the show on the HVX as opposed to the Varicam.
Regards,
Shane
Although it looks a lot more noisy, i thought that cinelikeD on the HVX would match the contrast of the Varicam better than cinelike V.
Maybe i am completely wrong, but the Varicam has a lot of lattitude to my eyes.
Could you post a frame grab of the same scene from both camcorders ?
thanks
Shane.
SCENE NAME :VARIC
That is interesting,
V DETAIL LEVEL: 5
V DETAIL FREQ: THICK
Seems like you are raising one level and then turning it
off with another? Did you compare shooting with
no V DETAIL LEVEL and shooting in THIN?
V DETAIL LEVEL: 5
Thats a good point, the basis of this file was taken from an SD version so the V detail freq had been set to thick and then transferred over. Try it yourself- change recording setup to an SD mode, change the V detail Freq in the scene file , then change back to HD. In HD the V detail Freq selection is blued out so I am guessing that it has no effect on the HD format. I'm going to record some frames and see , though. Thanks for pointing this out.
Shane.
Antoine,
cinelike D does have more latitude but cinelike V was , to my eyes , the better setting as it was less noisy and therefore a better match. Notice that I raised the pedestal to 3 in order to get more information in the blacks. I set the camera up in the field with a Chroma Du Monde chart but would like to really dial this setting in. Any suggestions are welcome.
One thing I did notice was that the varicam was picking up a green cast on the left side of his face and the HVX was just not seeing it although all the other colors were matching really well, I would assume that this was due to the increased sensitivity of the varicam.
Regards
Shane
Hi Shane,
If you could post a frame from each camcorder, i am very curious.
Indeed the HVX frame grab is clean. A little contrasty ( but sometimes that's what we want ). The cinelike V will always produce a much cleaner image than streching a cinelike D image (to increase contrast) in post.
thanks
Antoine,
I don't have access to the varicam footage, but believe me the two cameras were almost indistinguisable apart from the different depth of field. The varicam had a documentary setting which is not the standard "out of the box" scene file but I believe that the HVX could match any of the non-extreme scene files.
Shane
