Filip Staresinic
I recently bought my HVX. In the first tests I was dissapointed about its internal mic sound quality, it was poor with very low volume. But as I knew that I will not use this mic for recording and that I will use my Rode NTG2 shotgun I was not concerned. Now with rode the sound is better but not to much. I made lots of tests and combinations and if this what I am getting is its sound quality then I must say HVX sucks. I bought it to make movies and now sound is not good enough for this. I mean what should I do now, buy external sound recording unit that costs as much as camera it self?
The volume is not high enough, yes when I turn volume wheel almost to the end but then there is too much noise. I've read that on the volume meter the dots need to go to second line for best results. Yes they are going to it but the quality and volume are not there.
Just say is this normal. (speaking about in camera mic).When the volume wheels are positioned in the center so arrow goes straight up and I am 2m in front of camera I am getting the sound that is so quiet that I have difficulties to understand recorded speech. With Rode it is just a little bit better. In the best situation when mic is 1mm from actor and volume is set to be good enough the quality is still not there, my friends 500$ dv handycam has better sound. I can not shoot my films with this sound quality.
On the volume meter if dots just slightly pass second line a slight distortion of the sound can be heard even when mic alc is on.
If somebody has some experience about this, please comment.
