happysnapz
Hi All,
I need to buy a new camera but need to know more about panasonics hd and dvcpro formats.
My sony camera has likely bit the dust as it requires an expensive fix to replace the lens due to mould! Other than that its perfect but a bit out of date. I have used the dvx 100, 102A, 102B and have experienced some issues, including quite a major one but as I am in the market for a new camera this is probably at the top of my list. I dont like the look of the sony z1, the jvc or the canon mostly for the compression issues.
My questions here will concern the PAL version. Although dv has been my format I would like to shoot higher quality images for broadcast and cinema. My work has been varied including television, TVC's, weddings and shorts. Lots of run and gun 1 man band doco type stuff.
1. I shoot mostly dv so here is my first question. How does this camera perform compared to the DVX102 when using the hvx in dv mode? Light sensitivity, picture quality, chipset, lense? I have heard it looks pretty much the same and if I was only going to shoot dv then why bother with the hvx because its exactly the same image. Is this true?
2. Shooting in any other format other than dv requires using a P2 card I believe. So does this mean that all the compression issues found in hdv are fixed making this camera much better for fast action sports, fast pans, slow motion with no noticeable strobing and hdv mpeg2 artifacts, if so how has panasonic done this - is it not mpeg2 gop. Is speed ramping possible in post and is altering individual frames possible which can not be done in some other hd formats? Is there artifacts and strobing with the hvx?
3. I've seen discussions saying this camera is not true HD image size. Can anyone explain this issue please? I see there are about 20 hd formats in use and I am confused
4. Other than P2 cards, what else do I need for importing into FCP. Is firestore all that is required to transfer footage via firewire800.
5. Is this the first generation of the HVX200? Any idea when the next model is due for release?
Wow thats a lot of questions so if anyone can help, A big thanks.
Cheers
Happysnapz
Cheers
Happysnapz
