It appears that the native 720P frame rate feature (only records the unique frames ) will not be available for the Firestore. Check out this quote from the Japanese Site:
"In addition all codec which includes DVCPRO HD FireStore FS-100 of the FOCUS corporation which corresponds to AG-HVX200 (the next few days sale schedule) of making use (excludes native record mode) long haul record becomes possible."
If this is true then that means that when using the firestore to record 720P 24FPS you will be using the full 100mbs even though you are actually only recording 40mbs of unique data. Kinda wasteful huh? Bummer.
I guess that unless you want "slow-mo or fast effects" you might as well record in 1080 24P and at least optimize the use of the firestore.
Here are my calculations based on a 100GB Firestore (don't know what size it will be)
100 minutes of 720P 24P (over 60i)
100 minutes of 1080 24P (over 60i)
250 minutes of 720P 24P (native------not supported on firestore)
Pretty significant difference. I was planning on using the firestore and working in 720P to save space. But if this is accurate I might as well shoot 1080P and get the most "bang" for my buck.
It's still a better cost per GB than P2 however. I wonder if the variable framerates downsampled to DV will work from the firestore?
