Richter Video Equipment
Hi everyone,
I have a few questions about caring for my cameras.
1. Is there any reason NOT to store them in a pelican case? Right now I unpack them and put them on a shelf, but would leaving them int he sealed case cause any problems? It would be nice to have them ready to go all the time pre packed but I was concerned about any damage from them sitting in a tight foam container long term. Also I figgured they would have a better chance surviving fire or flood if in the pelican case. I can also lock the cases to prevent theft.
2. Shortly before I got my first p2 cam i heard from an unconfirmed source that you should not store the p2 cards in the cam. Is this true? What would get damaged if they are left in there all the time. It would be nice to not have to always remove them and put them in cases although if leaving them in cam would damage them or the cam its worth it.
3. Since the HPX does not have heads, is there any other maintenance I should be doing? If the heads are not being used on the hvx do they need an annual cleaning or anything? I always clean my dvx heads every 20-30 hours (non abrasive cleaning) but don't know what is required if heads are not being used or the cam has no heads.
P.S. this site has 170 maintenance, but 2 of the items don't apply since there is no tape deck. http://www.tekmg.com/Panasonic/Camcorder/AGHPX170.aspx
