HI all
I treat my HVX's like a fragile egg, however, on a recent trip I had a stud mounted on the handle. Unknown to me at the time, it was placed in a padded portabrace style case with the stud and an accessory still attached to the stud, it was then put into a trunk where the deck lid closed on the case, applying pressure on the stud, and it and put a crack in the handle just behind the 1/4 20 mounting stud/hole.
I was looking at it closely and believe I can replace the handle without any tech benching or factory repair rep, but I don't know where to get one or where, on panasonic's site, I can obtain a new one. It is an original HVX200. I only need the top cast aluminum (or whatever it is made of) portion, not the whole handle. The handle looks like it is made in two horizontally sandwiched pieces, with the top portion separating from the bottom.
I will jinx this and state, it looks like a pretty easy fix.
Can anyone point me in the right direction here?
David Walker
Mail@mediamagicproductions.com
David Walker
