Barry_Green
Moderator
Hey, I was rooting around on the Panasonic site and found that there's now a description of what the HVX firmware update (2.0.3, released last October) actually does.
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/hvx200/hvx200.htm
Looks like three main things are addressed:
(1) Dubbing function does not work when 1394 CTRL is set toEXT.It is solved. (NTSC only)
(2) When the time code is preset via 1394 in FREE RUN mode of P2,the time code value is not kept after tuning the power OFF.It is solved.(NTSC only)
(3) Notch filter function has been changed so that it does not work when LINE is selected.(PAL/NTSC)
Here's their pictorial description of how to check the version # of your firmware:
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/hvx200verproc_e.htm
And, it looks like another firmware update will be coming in May. The HVX200/202 needs a firmware update to work with 16GB cards.
