nsoltz said:Every so often, I get stuttering in the Canvas, and this is with 720p 60 material, which I am editing at the moment. I am also taking my HD out of the computer either through a Kona 2, through SDI->DVI converter to flat panel OR to a future product which I cannot name. That video never stutters even if Canvas stutters. I cure the stuttering by turning off external video and then turning it back on. So, I would recommend to anyone experiencing stuttering, regardless of whether you are monitoring external or not, to try toggling external video or even mirror on desktop. It is definitely something in FCP 5.1.1 (perhaps in 5.1 as well).
Ned Soltz
robbo said:Hey Punch - that's great it worked.
It is related to the camera settings though, and therefore how fcp interprets the footage. I don't even have the hvx yet so I can't offer any detail as to what the exact menu setup should be. Have played around with dl'd footage from it quite a bit, tho ...
And in regard to either the Viewer or Canvas stuttering on playback - are those windows set to "fit all" ? If they're not - then that very often causes the kind of thing you're describing.
PUNCH said:huh, looked at the settings on the HVX200...not much to set.
filmstox said:This is definately an issue with FCP and is not a camera setting problem. I am beginning to suspect it may have to do with footage imported on 5.0.4 or 5.1 and then loaded into a Universal project. I have more testing to do. It seems to plague only certain clips and even then, it seems to come and go depending on the render. I did find that having the transparency set on the offending clip set to 99% forced FCP to rerender and seemed to smooth things out. Return the clip to 100%, rerender and the issue returns.
Very strange.
-filmstox
