HVX 200 Huge Kit For Sale
SELL ALL FOR 4600.00 (discount over individual prices) OR INDIVIDUALLY
IF YOU BUY THE KIT I'LL THROW IN BARRY'S BOOK AND 2 DVD'S
PIERRE: 503.267.7919 pierre@monstervsrobot.com
HVX 200: 259 Hrs 5599.00 LIST SELL 2200.00
with10 batteries and 2 Pan A/C chargers
Century Optics .6 W/A LIST 490.00 SELL 300.00
Ideal for shooting situations in which zooming isn’t needed. The .6X attaches to the front of your video zoom lens for 40% wider angle of view and minimal distortion.
Partial zoom adapter, allows zoom capability from wide angle to mid-range when using the camera in auto focus mode.
Comes in our popular Bayonet Mount that attaches with a twist to the front of your HVX200 13X lens.
For greater protection, the face of the unit offers 102mm threads for direct attachment of Schneider 102mm clear UV filters.
Century Optics .75Extender LIST 775.00 SELL 500.00
Wide Angle Converter, the right tool for shooting situations that require both a wider angle of view and full zoom capability. Increases the field of view by 25%. This professional add-on lens produces crisp, high resolution images with low distortion, and superior contrast edge-to-edge. Interfaces directly to the bayonet mount on the front of the lens for quick and easy mounting & removal.
Varizoom Rock PZFI remote LIST 299.00 SELL 150.00
Specifically designed for Panasonic HVX200, DVX100B, HMC150, and HPX170 cameras, this is the first and only zoom, focus, and iris control. This powerful combination offers precise control over these three camera functions. Operator may switch between auto and manual control for focus and iris at anytime. Works on all camera supports, stabilizers, tripods, & jibs.
Fig Rig/C-stand base
LIST:299.00 Stand 199.00 SELL COMPLETE 300.00
Padded Hand Grip
For a comfortable and secure grip even in the most extreme environments.
• Cable Clip
Supplied with 4 cable clips to keep all your wires wrapped cleanly around the rig and out of your shot.
• Crossbar
The camera bar is threaded with one 1/4", 3/8" and 5/8" hole for additional accessory mounting.
• Rubber Base Padding
A non-slip rubber pad provides stability when using the Fig Rig on a flat surface such as a table, floor or railing.
• Sliding Quick Release Plate
Supplied with a 501PL sliding QR plate allowing you to position and balance your camera. The plate system can be switched out with a variety of Manfrotto plate assemblies to best match your camera.
• Accessorize Galore
Mount any number of accessories that are necessary for today's cameras. With the use of the optional 595CLA you can convert the Fig Rig frame into a fully loaded roving cine rig precisely positioning your mic or monitor anywhere around your camera. Add on a Manfrotto 521 series remote control and now you have complete fingertip control of zoom and focus.
Marshall 7” monitor V-R70P-HAD Panasonic Battery back and A/C power cord. Velcro Hoodman LIST 1299.00 SELL 900.00
The Marshall V-R70P-HDA is a very high quality 7-inch LCD monitor designed for video-assist and general field production. This monitor incorporates sophisticated images processing, scaling and interpolation for optimum analog to digital conversion and the best possible picture display. The 3-BNC Component Video input will decode both standard definition and HD signals. It can be run off Sony-type V-mount batteries or any 4-pin XLR power supply. A 1/4-20 mounting plate can be attached to any edge of the monitor. A rack mount kit is available as an optional accessory.
• Image Conversion
The V-R70P-HDA as the ability to accept analog video signals, even very high quality 3-BNC HD/SD Component Video. Analog signals are digitized using an advanced 10-bit process with 4x over-sampling and adaptive 5 line comb filter. Video is scaled to fit on screen in the highest resolution using a state of the art LSI that incorporates 4 x 4 pixel interpolation with precision Gamma correction to product the best images available.
• Built for Field Production
This monitor has an optical grade polycarbonate screen cover that is scratch resistant while defeating reflection and glare. TFT technology gives the monitor a wide viewing range of 130° horizontal and 120° vertical. Its bright readout can be seen in even in difficult ambient lighting conditions.
• Widescreen and Conventional World-Wide Compatibility
The V-R70P-HDA can display 16:9 and 4:3 aspect video as native images. The unit also auto-detects both NTSC and PAL system video so it can be used almost anywhere in the world.
• DC Power Options
This monitor was obviously designed for use as a field production tool. If your camera package uses the popular V-mount batteries, this monitor can be powered in the same manner. The manufacturer estimates a single fully charged 50 watt/hour battery can power the monitor for 4-6 hours. A 4-pin XLR input allows the unit to be powered via any professional DC power supply.
Firestore FS-100 160GB DTE Hard drive 999.00 LIST SELL 600.00
with A/C adapter,cradle and extended life battery
Featuring a comprehensive backlit display, an easy-to-use menu system, a built-in hard drive, and a removable, rechargeable battery, the Focus FS-100 is the perfect DTE companion for the Panasonic camcorder. Audio, video, timecode, and control information is passed through a single FireWire cable, allowing you to record directly the the FS-100's internal hard disk. The FS-100 includes a six- or ten-second electronic shock cache to ensure that you never lose footage. Advanced features such as time lapse, retro disk recording, scene marking, and clip categorization make the FS-100 Portable DTE Recorder the perfect companion for handheld shoots. When recording is complete, your footage is ready to edit instantly—no capturing, file transfer, or file conversion is required.
Do you still have this unit? PM not working on the site at the moment.
Hi
So I've sold the HVX, Firestore and Varizoom. I'm relisting the other items with reduced prices to get it all out the door. Buyer pays via Paypal and is responsible for shipping. I'm a verified Paypal biz and this was my personal gear-well cared for. pierre 503.267.7919 pierre@monstervsrobot.com I'll get these faster -PM me as a last resort. thanks!
Century Optics .6 W/A LIST 490.00 SELL 275.00
Century Optics .75Extender LIST 775.00 SELL 400.00
LIST:299.00 Stand 199.00 SELL COMPLETE 250.00
Padded Hand Grip
• Cable Clip
• Crossbar
Marshall 7” monitor V-R70P-HAD Panasonic Battery back and A/C power cord. Velcro Hoodman LIST 1299.00 SELL 500.00
• Image Conversion
• DC Power Options
THIS IS ALL THAT'S LEFT
BUY THESE BOTH AND I"LL THROW IN BARRY'S BOOK AND 2 BOOTCAMP DVD'S
buyer pays shipping. Payment via Paypal to verified address thanks!
