VaricamLife
The footage was shot at 720pN.
Imported the media into FCP using the Import P2 fucntion built in (FCP 5.1.1). That all went down fine.
Check the Item Properties > Format and it says frame rate of 23.98 and compressor is DVC Pro HD 720p60. That's all fine as far I as know.
I'm scrubbing through the clip in the viewer. If I go frame by frame, every 24 frames I reach the next second. So that's fine, no worries. However the frame numbers are throwing me for a bit of a loop frankly. The frame numbers break 30 and count all the way up to 60, sort of, it hits like 58 and then goes to the next second at frame 01. Now I gather this has something to do with Native setting, but I'm just not grasping it and would appreciate if someone could break it down a bit for me. Everything seems fine footage wise, but with this as my first trip into P2 land, seeing frame numbers into the 40's and 50's is a little weird.
cheers.
cheers.
