Jay Nemeth
I used the right sized screwdriver, pushed it firmly into the screws, and removed all four of them without having to do anything else. The blue locktite will simply crack free with the right amount of pressure. I used the same screws again to attach the chrosziel plate and have had no problems. There is no shearing force unless the screws are loose and the plate can wiggle around. It's the pressure of the chrosziel plate being pressed to the the camera that makes it a solid installation. If the heads are are even slightly stripped, you won't be able to tighten them adequately.
