HPX300 Redrock M2e DOF Test
When you were shifting focus from one object to another, the picture shifted all over the place. What lens were you using?
I was using a Zeiss 85mm during this shoot. As stated, I just put this set up together and still working things out.
I am using the reverse scan option with the m2e upgrade. I have not bought the achromat that comes with the m2e as I am using the older 72mm achromat. I wonder if that is making a difference? Maybe I still need to make some more adjustments with the back focus.
Yes, indeed! You should use the new 72mm 5x Achromat (Encore) for the sharpest resolution.
Set-Up info posted by Brian Valente, from camera to front setup...
Camera
82-72mm step-down ring
72mm blue coupler
1" 72mm spacer tube
72-55mm step down ring (part of hard mount kit)
55mm coupler (part of hm kit)
zoom approximately 38mm
focus all the way crashed in (approx 2m)
macro mode fully on
http://www.redrockmicro.com/forum/viewtopic.php?t=7312&start=0&postdays=0&postorder=asc&highlight=
Cheers!
H.
