surfcitizen
Was shooting today on my HPX250 at AVC I 100 30p using CINE D & PAP 1 with mostly excellent results. It was under a bright noon sun with some light passing cloud - not a low light situation. I was able to keep the iris close to 4.0 most of the time by using ND 1/64 and a circular polarizer and was getting nice results from the full zoom range including both ends. However a couple shots are WAY soft and I'm trying to figure out why as the remaining 40 shots are fine. Here's a link to the 2 shots if anyone has any ideas on why this is happening.
I'm aware of the issues discussed with this camera and have mostly been able to work around them but can't figure why these shots went soft and the rest don't. As you'll see, I pulled back on the first shot from full tele to full wide and just before hitting wide it went soft. The next shot was zoomed in some but still remained soft and then came clean right at the end of the tele range. I did the same at least five times before and after without any problems - and without changing anything on the camera. Any input would be much appreciated.
https://vimeo.com/61318084
