Hi all. I’m new here and I have a P2 card problem and was wondering if any of you could help; I haven't seen any solutions so far.
I’m shooting on an HPX-170. Prior to this incident, the card had been working fine, as had my other cards (I have three total; the 16g that came with camera and 2 Panny 32 gig E-series cards). The problem occurred when I powered the camera on out in the field. A few minutes before, I shot some footage (had been shooting fine all day) and turned the camera off. When I turned on the camera again, I had the “RUN DOWN CARD 2” message on one of the 32 gig E-series.
Basically, my situation is as follows. When I put the 32 gig P2 card that errored in one slot (doesn’t matter which) while a card is in the other slot, I get the “RUN DOWN CARD” message and it displays the “E” as opposed to the “1” or “2” normally displayed. When I put in the 32 gig P2 card by itself, I get the “FORMAT ERR!” message; the “E” is there again. I tried to grab data by plugging the HPX into my PC (running XP) with USB and simply copying files over, the card did not register as a drive in either slot.
It seems I should reformat the card but I want to get the footage I have off the card before I do that. First, is there a way to do this? And second, why does a brand new card display the “RUN DOWN CARD” message? Is it a bad card? My other 32 gig card is one serial number away from the problem card; should I worry about that one as well?
I would really love to find a fix but can’t seem to on my own.
Thanks.
Thanks.
