Tim Visual
Hi all,
I may be butting my head against the wall with this one, but I'm hoping some genius out there has a solution, if one exists.
I have an HPX170 that I'm using with an Atomos Samurai recorder. Here's the challenge. I would like to record to the Samurai in 720p/24 --- and not to the expensive P2 cards with the more difficult workflow. I set the recording format to 720P/24P, and the MCR Format to 720P/24PN (there is no 24P, only PN choice). The Samurai gets its instructions and feed from the MCR Format, through the SDI cable.
The Samurai doesn't recognize the 24P output from the camera, so it only gives two format choices to record: 1080P/29.97 or 1080i/59.94. So I choose one, and the result isn't great.
On most clips the motion is okay, but with certain types of motion, it appears real jerky. Upon closer examination, I find that there's some sort of pull down thing going on with frame duplication occurring at different intervals, depending on if I output at 720 or 1080i (in the MCR Format).
Also, if I bring the footage into After Effects, I get the frame duplication issue and jerky footage. If I bring it into Final Cut Pro X, it does some frame blending/interlacing thing which doesn't look too great either.
I'm thinking the combination of this camera and the Samurai just won't play together to get a clean 720P/24 without some funky conversion. The option is to shoot all at 1080P/30 and convert in post, BUT, if I don't need that res for my projects, it's a huge waste of P2 card and/or HD space on the Samurai.
Any ideas out there would be much appreciated. Thanks!
- Tim
- Tim
