HPX 170 scene file
aaron_mandel
Hey I'm new to this and can't find any info to help me. When I load scene files onto the camera will there be six different options(the dial) in every scenefile or are they all the same. To clarify, I save four scene files to my sd card, bring them into my comp and move them to trash and then drag and drop 4 downloaded scene files back onto the sd card. Let's say I load the one called align, will I have six different options within align by using the dial or will F1-F6 all be the same. I am getting an HPX 170 tomorrow.
Hi aaron,
You are close to the mark. Just look at one scene file as a way of setting 6 individual camera setups. An example would be a scene file for Cine D and F1-shutter180/12fps; F2-shutter220/18fps;F3-shutter 280/28fps; etc,etc. You get the idea. Once you setup the six F1-F6, if you save that setup to a scene file it will save all six individual settings to that particular scene file name that you give it. You can only have 4 scene files and 4 user files per SD card. If you set your scene file back to factory default you will end up with the six original settings that the camera came from the factory with.
