HPX-170 Outputs
Ok, so at CineGear I tested that both the HD-SDI out and standard def composite output will work at the same time. What I'm wondering is if anyone knows if the HD-SDI Out and the Component HD out both work a the same time. It would be nice to use the HD-SDI out to a client monitor and then use a small, inexpensive IKAN for an on camera.
Does anyone know if this will be possible? Seems like a simple question but I know the 200 could not go component and composite at the same time...
