C Chadac Member Jun 12, 2010 #1 How do I get the progressive look in final cut pro if I shot in 1080i 24p? If I shoot in 1080i 24pA will in automatically transfer into FCP as progressive?
Jarek Zabczynski Veteran Jun 12, 2010 #2 Take the 24p into cinema tools and reverse telecine it to native 24p. 24pa will take out the frames automatically on import.
David Jimerson Administrator Staff member Jun 12, 2010 #4 If you want to edit as 24p, which you should do if you have 24p material, then shoot 24pA.
David Jimerson Administrator Staff member Jul 2, 2010 #6 Once you remove the pulldown, yes. (STANDARD NOTE: DEINTERLACING IS NOT THE SAME THING.)
