I do not know what your particular timer means when it says "99 max." On mine, however, "99 max" means 99 is the most it will count to - it will go beyond that if you want but it won't count those. In other words, 99 is the maximum you can program into it and if you want more you just have to set it to infinite and stop it manually when you're done. However, that may not be the case with your timer.
I have a TM timer. "TM" is all I remember about it and there's no clear brand marking on it... But I highly recommend it. It works very well.
Hey thanks for the advise. Could someone confirm that the model I am looking at on ebay will not do time lapse photo's?
I really don't see what it does if it does not do that.. :undecided
http://www.ebay.co.uk/itm/170765949...AX:IT&_trksid=p3984.m1438.l2649#ht_2799wt_843
I have what appears to be the same one that works for both GH1 and GH2... AlBut someone else will have to confirm that the timer for the GH1 will also work with the GH2 - I'm not sure that it does.
