How to shoot with Continuous File Numbering?
HST
I don't see an option in the menu or could find anything in the manual.
When my editor imports to FCP the files are numbered 001 and up everytime a new card is used. I'd like to program a continuous file numbering system, so that we don't get duplicate file numbers everytime a new card is used.
Anyway know how to do this?
No one else having issue with this? My editor is having major problems and is having to edit offline as our Editshare points to the wrong clips because of this. It seems like there should be a setting for the camera record files with a distinct or continuous numbering scheme.
I was actually going to post a topic exactly like this. I'm wondering the same thing.
It's a huge setback that everytime you format the card it starts at 00000. Canon DSLR's keep counting up and only repeat after 9999 shots.
HST, one thing I recently did was pull out all the MTS files into a folder and used the program A Better Finder Rename to append new info into the file name. It can add info to file names based on the time the file was created, the name of it's parent folder, etc. It's got tons of options. It's a pretty fast way to alter the original file name so you don't run into issues finding the right clip if files go offline and you have twenty "00000.mts" files in your project. Using A Better Finder Rename is an extra step to importing but it's really no different than what you'd do with Log and Transfer in Final Cut Pro.
Then again, I'm pretty new to the whole MTS file thing... I usually keep an entire copy of the SD card on my drive. Not sure if pulling out the raw MTS files is a no-no.
It is a ball ache. Usually, when backing up (on a Mac) I 'copy' the whole drive (as it appears on the desktop) and paste it to an external drive - which creates a folder called 'NO NAME' with all the data in. I then re-name this folder Card One, Two etc. Is it not possible, when log and transferring (or after) to then assign the card name, as the reel name for those clips in FCP? (Just a thought, I don't edit...)
