Hi
I want to buy this camera so i have taken it from a rental company in order to make a test and i have test it in HD and DVCpro50 and in both i have get a very bag image as it has a bit of glow and the colors look bad so that my old DVC-200 in dv look a lot better then this camera.
as i have understand from reading all the review on the net there are a lot of parameter that you need to setup in order to get a good image, how i have the same bad result with the new Hpx-174 so it can all be that i don't know how to setup the camera in the right way and for that i need your help,
as every time i rent a camera it always for one day as i also need to shut with it and so i don't have any time to learn how to config it in the right way also in the pdf of the camera there is no info as how to setup all the menu to get a best result and as you have understand as this camera is from a rental company all the setting are a mess as a lot of user have play with it.
so if any of you can send me how to setup the camera in a step by step in the menus it will help me a lot
i need to config it to:
PAL
DVCpro50
interlace
i work after that with Avid MC 3
so all the work are in SD
Tamir
PAL
DVCpro50
interlace
Tamir
