How to set HPX 370 for DVCProHD 720p 30pN?
vicrattlehead
Have a shoot in the AM, and need some quick help:
Can someone post the menu combo required to get the 370 to record DVCProHD 720p 30pN? It's so easy on my HPX500, but I can't get it to work on the 370....
A thousand thank you's!!!!!
Menu: (rubber button on side of camera)
2: System set-up
System mode: 720-59.94p
Power down and back up
Menu:
2: System set-up
Rec format: Dvcprohd 30pn (It's down the bottom of the options off screen so you need to scroll down to it with the wheel)
Note if you don't know you use the wheel on the front to select the option and then press the wheel to set it.
hope this helps
