I don't know. I'll have to check. What drill bit type should I be looking at so that it's able to drill a hole?
Okay, I finally have the time to look at it. The problem I see is that it already have a bunch of holes already. But the holes do not line up with the holes in the JuiceDesign's base plate. So, my next question is, is there some other riser similar to what I got that will have the holes line up or that has no holes so I can drill it myself?Just a standard drill bit for metal. I would measure the distance between the threaded holes that you want to use on my base plate then make sure the new hole you are drilling on the other part matches that distance. Using a center punch before drilling is a good idea so the drill bit doesn't drift when you start drilling. If you aren't comfortable doing it you could always find a local machine shop that could probably do it for you for a few bucks.
