disjecta
Lucky Duck
I'm sure this is obvious to a lot of you but to others maybe it's not.
Once you go through the excrutiating trials of balancing your camera on a Glidecam 4000/2000 and then you need to transfer it back to your tripod, how do you go back to having it balanced without investing another hour or so?
Simple, order a Bogen quick release plate (3273) and attach it to the top Glidecam plate. Mark the exact position of where the camera connects with the plate with white-out or a paint pen or whatever. When you slide the camera back onto the plate on the Glidecam, match up the marks you made and you have instant balance again.
I just received the plate today and tried it and it worked perfectly. In my opinion, this is the only way to get rid of the constant frustration of having to rebalance and be able to use the Glidecam at all.
I hope this hint helps someone out.
