How to import raw avchd files to final cut!
asteele10
I had a little issue and lost my final cut project. Luckily I saved the raw avchd files which I just dragged and dropped off my SD card.
However, I'm not able to open these in FCP (or in any other program). On my drive I go to: AVCHD - BDMV - CLIPINF to get to the files. What do I need to do to import these in to FCP and convert them to .MOV's?
Thanks!
Thanks!
I believe you're opening the wrong files, you'll want the MTS files, which are located in this path:
AVCHD -> BDMV -> STREAM.
But, before you even drag and drop those back to your work folder...follow these steps.
The best way to re-import into FCP:
1. Open FCP.
2. Open the Log & Transfer window
3. On the upper left corner of the window, there will be a Folder icon with a "+" on it. Click it.
4. If your files are on an SD card, skip this step. If not, direct your finder window towards the raw, top level AVCHD folder that contain your videos. Select the folder and click "open". The video files should load.
5. Next, Make sure your import settings are correctly set. Click on the "settings (gear icon)" button and select "preferences"
6. Next to AVCHD, select your preferred codec (ProRes 422 xx, AIC, etc.). Small projects, i usually use Pro Res 422 LT.
7. Once the settings are set, just drag all the clips you want into the "Drag file here" area and you should be good to go!
Enjoy!
Okay, I have a question for you: Can you backup to external harddrives or does it have to be saved on an SD card? This is the layout of my camera, which NO NAME being the camera? So can I simply copy the AVCHD folder and all of its contents and be set?
Thanks!
Here is the link to the picture:
http://robertbmeyer.us/file.tiff
file.tiff
