Look at your scopes; if they hit 0 on the waveform, they're true black.
If you're rendering, though, the gamma curves of your format may lighten the blacks.
What do you plan to do with the video once you render?
First option is that your monitor is calibrated poorly. Most likely. Second, black level is often pushed up for broadcast, so your footage, depending on what you used to record it and on what settings, could easily have a black level that is not low enough. You can correct this with levels, I don't know where it is or what it's called in Vegas. Contrast will affect the whole image, black level (or curves) will only affect the lower end. You can also check the settings on your camera to see if you can drop pedestal or black level. I usually do, I like crushed blacks.
i always settle on the color correction preset "studio>computer RGB"....looks like true black on every tv i watch (it) on.
i rfealize that there are more technical and true methods of acheiving this, but no-budget.
