how to focus lens on infinity in dvx
Hi,
How would one "set the focus to infinity" on the DVX?
I noticed that the focus only shows up on the LCD or EVF as 00-99 (M or A depending on manual or automatic mode) and that there are no infinit indicaters on the focus ring itself.
There's a "push to infinity" setting on the focus switch. Just push the switch all the way down and it sets the lens at infinity.
just to clarify, focusing on infinity is having everything in focus correct??
no, it just means focusing into the infinite distance
you can have some things, for example; near to you that are not in focus
and then from a certain point after everything up to infinity is in focus
Which I have found to be a real pain sometimes, when filming something far away and its getting closer to you, you gotta be good with that focus ring (if your in MF that is).
