F5: How to firmware update Sony F5
Kandre
Need help! The company I work for has just bought 2 Sony F5s and we are now trying to update them to firmware v4. The camera is now on v2.10. At the store they told us to just download the firmware and copy it to the SxS cards and then the camera would recognize it and ask us if we want to update. This isnt happening. We have tried different methods, but no luck yet. The problem is that we need them to be in firmware v4 as soon as possible. Any advice?
do not copy to your SxS cards but to an SD card and put that into the SD card slot.
should do the trick. Use a big battery or DC power for the camera and let it take time to do the upgrade.
DO NOT SWITCH OF!!
If it's not obvious, steps 4, 5, 6 follow steps 1,2,3 from the "performing the upgrade column on the right of the first page. As Thomas said, do not switch off until it tells you to, there is also a pause between the 2 step update. Be patient and let in run it's course. You may also want to do a All Reset after the update.
Thanks for all the help guys! :)
That solved the problem.
But i have run into another.. the optitek fz to ef adapter
