FS7: How to disable audio tracks
When importing footage into premiere I notice there are 8 tracks of audio. I've set the first 2 for inputs and the second 2 for internal camera mics (scratch audio). How do I disable the other 4?
You can do this in Premiere easily. Select the imported files in your project bin, right click , select "audio" and you can select how you want the channels routed. Then when you drag them into your timeline, it will be how you set it. You can also set this as default for the future.
Yes, easy to fix in Premiere, but to answer your original question, there is no way to disable audio tracks on-board the camera. It is what it is.
