I'm going to be using Final Cut Pro Studio 2 to convert footage which has been shot at 24P on a Varicam, to standard defintion NTSC and PAL versions. I dont have the actual footage yet but I was wondering if anyone could give me any advice so that I don't end up with stuttering motion in the converted files.
Can I capture the footage at 720 24P and then drop just it into NTSC and PAL sequences? Or should I be using Prores instead? Should I let Compressor handle the conversion - or should I use a Nattress plugin?
So many options, I'm not sure which is the best workflow.
I'd be grateful for any advice received.
Many thanks.
Many thanks.
