And one more thought-
The F35 always saves your menu so i'm assuming the last menu you went to was to make the SDI output clean.
If you were to press the buttons to open the menu, even though you can't see it, you are in the last menu you loaded.
Click the clicker once and then spin it, with some luck you can blindly turn the overlay back on because the menu should still be the first to open.
Same with F35. But menu was turned off on monitor out. This is the problem. I need a sony evf or do it by ethernet. I can't get hold of sony evf. So must try ethernet. I read it was easy. Maybe I'm missing some detail.
I also found this tip from yachacha and tried it too. But didn't work. I guess it was not last menu changed:
I don't know if there is some way of resetting to factory settings without the menu. I read doing firmware update reset to factory. But my camera is already latest firmware. So don't know if doing it again would brick the camera or something.
Does reseting everything give tou menus out the sdi?
Can one of us upload user settings and let you download them and install via SD card?
Hey good news. I actually have a friend who has a F900 for paper weight I never knew. He shoots F55 and FS7 now but the F900 is stuffed somewhere. Didn't even know he has this. F900 evf should work right? We will meet.
