All the Canon APS-C cams do about 46mbps in 1080-30p and 42-44mbps in 1080-24p.
On a side note, with Magic Lantern and a good SDHC card you can get a 1.4x bit rate or about 62mbps with audio. If you disable audio you can get 3x or about 84mbps. I have a T3i and get 60-65mbps clips reliably using ML. ISO 1250 - 2500 seems to be where the higher bit rate helps most. At lower ISO's I don't see much advantage to the higher bit rates.
By the way this is probably the wrong section to be asking this question. Lot's of folks using 60D's in the APS-C forum
I'm surprised the question got answered in ANY section so kudos to you for doing so, thank you. It seems like if you want a question answered you either have to make up a sensational headline (as I had to do with my "destroyed 5D" post) or ask what kind of mic to put on top of your camera. Even though you can't get dialogue that way it has to be the single most talked about subject at DVXUser.
