I use FCP 7 to import with Log&Transfer, but FCP sees the clip as two clips. Both card slots are visible in the Log&Transfer window. Do I miss something?
I found out that the clip on card one is splitted in two, because one chunk is nearly 4 GB. The second chunk is only 200 MB. On card two the clip is around 1 GB and only one chunk. Perhaps, the problem is that the whole clip is splitted up in three chunks: On card one, because the file size was exceeded and then because the capacity of card one was exceeded. The whole clip lasts, or should last about 45 Min.
well .. at least it doesn't stop recording . like the 5D it's interesting is doesn't have some way to note a "span" on the same card (e.g.,
4GB file limit spanned to next file ).
I shooted a new clip, but it is still the same! The AF100 says when I stop recording, Relay Rec stopped. That should have worked, but in FCP7 I see the clip as two clips and can not import as one clip. Why not?
