How does 12 bit sampling improve the DVX images
Aejaz
I was reading a DVX review and it says:
''The DVX100A continues on this revolutionary tear with a 12-bit DSP that enables substantially more precise sampling than the 10-bit version it replaces. The 12-bit DSP is capable of assigning one of 4,096 possible values to every sample as opposed to only 1,024 in the previous model. Eight-bit cameras can assign one of only 256 possible values — a limitation that may deleteriously impact the reproduction accuracy of our images''
I was wondering how it actually happens?
Re: How does 12 bit sampling improve the DVX image
[quote author=Aejaz link=board=Events;num=1087120433;start=0#0 date=06/13/04 at 02:53:53]I was reading a DVX review and it says:
[/quote]
2^8=256
2^10=1024
2^12=4096
This in essence determines the number of shades of grey that can be represented from pure black to pure white. It improves tonality and contrast.
Yes, but after the processing is done, it gets rounded off back to 8 bits for encoding (DV is an 8-bit compression scheme).
So 12-bit processing makes for more precise image calculations (for things like the color matrix adjustments, the white balance shifts, anything that modifies the image in-camera). It's like working with decimal points -- the 12-bit system has two more decimal points of precision than the 10-bit system does. It makes for more accurate calculations and minimizes rounding-off errors.
The difference, in my limited experience with the 100A, is not substantial. It almost certainly makes a difference, but it's not night and day, heck it's not even 10:00 and 10:30... but more precision is always better than less.
