how do you suddenly transition between 240fps and regular film speed???
I've noticed this editing effect in a number of FS700 clips posted on Vimeo that some sequences shot at 24fps are suddenly slowed to 240fps at a certain moment in time.
I understand that's an editing decision. But how is that done? I saw an FS700 clip where a surfer is riding a wave at normal speed, and all of a sudden the edit slows down to 240fps. Or was that effect done in camera? And if so, how?
You shoot at 240p. In post you do a time ramp from 10x playback speed (which looks like real time 24p footage) to 1x playback speed (which is 1/10 speed of realtime). Your NLE manual should tell you how to do that.
Hi Drew, just had one more question concerning this technique. I just tried to do this type of edit in Adobe Premiere Pro. I cut my 80 second 240fps slow motion test at 60 seconds so that the first 60 seconds is sped up 10x to 6 seconds at 24fps.
What I don't understand is that my sped up now normal speed clip looks more like 12fps as opposed to 24fps. It seems to be super fast rather than normal 24fps. Could this be because of my fast shutter speed (1/500)???
I must be doing something wrong here, but I have no idea what it could be.
Thank you very much in advance for any further help you can give me.
https://vimeo.com/49092636
Everythings working fine on your clip. Strobey or clear effect youre seeing is from the shutter speed.
I dont know much about post but it would seem that there are two ways of getting 24p out of 240FPS
1) throw 9/10 frames away - result jitter image
2) merge 10 frames at 10% opacity - or some other 'intelligent' process - result silky smooth image
I guess full understainding of your NLE is required and you may need to process the clips in dedicated SW like twixtor to get the right look.
S
S
Neither of these approaches will yield the correct result. As Drew explained, above, the correct way to do this is to speed up a portion of the slomo footage by 10x by changing the framerate, in post, to 240fps.
In Premiere Pro the default is 1. To get 2 (which is far better), right-click the clip and select "Frame Blend".
You can add motion blur in post to the intended 24p sections , unless you were going for the fast shutter "strobey" look . Motion blur is calculated by examining motion vectors, so areas that move faster get more blur, static areas get no blur.
I think cuervo was referring specifically to the ramping: the transition between 240=>24 . Down ramping in software is either done using
a) dropped frames
b) blended frames
c) motion interpolated frames (generates new frames)
As atticus mentioned, the options in premiere are a) dropped frames, and b) blended frames. Option c) is normally done in software like after effects, twixtor, nuke etc... Older versions of Premiere actually had Timewarp as a plugin . Each method has pros/cons, but c) usually produces the best results. New intermediate frames are generated from motion vectors so motion is smoother (effectively you have more than 240 FPS to play with, so the ramping is smoother)
