I'm just using the LUT which comes in the camera. I see MUCH less highlight detail with LUT on. Why the LUT is final result if I won't grade to match the LUT? Its not final result in this case.Most people in video/film production will use a LUT so they can see a better representation of what the final product may look like (especially if they are editing it). If you're using one that's crushing the image then you're using the wrong one.
I tested myself off course. I have F35 for many, many years now. I just want to see how others do to compare. ;-)Per usual the best answer is testing yourself because if someone (for example) recommends you should overexpose by a stop or two you might as well then also ask for his or her post-production workflow because you don't know what else is being doing to produce the final product.
I personally always use LUT on camera or 7q, i have come to trust 7q a lot on exposure. I find exposure to be very sensitive on F35. There is only a small margin or error before you loose that nice fine grain or blow out highlights. But most cameras are this way. Test test test your own system until you know how it will act in any situation.
Ever notice on a major set, the AC control’s focus, an operator may move the camera, but only a DP adjusts the iris.
I'd simply set my light meter for ISO400 and shoot away (pushing one stop to 800 ISO, if I absolutely, desperately, needed the extra highlight latitude).
