chiefr_suthrland
Just purchased an Edirol R44 off eBay and a MixPre off Craigslist. Wondering what kind of cable I need to connect the two... :huh:
To feed the MixPre into the R44, you'll need two XLR-F>1/4" TRS cables. Connect each XLR out of the MixPre to one of the inputs on the R44. Be sure to set your MixPre outputs to LINE, and to reduce the input sensitivity on the R44 to accept line-level in. Also, trun off the phantom power for the inputs on the R44 that are receiving the MixPre.
why do I need two cables?
Each XLR cable is mono, so if you want both channels from your MixPre mixer you need two cables.
i have the same setup and whenever i add the Mixpre, i see no advantage gain
Regular MixPre or newer digital model MixPre-D? If I recall, the R44 has a digital In. Not sure if the two are compatible digitally, but if they are, AES / digital would be the cleanest.
I find that nothing lower cost beats the audio quality of the Sound Devices preamps, so adding a MixPre to the mix produces a nicer sound. ( not a huge difference, but noticeable when you do A/B comparisons )
It should, according to the manual diagram the R44's TRS and XLR inputs appear to be in parallel with each other. Be sure to set the R44 input sensitivity to +4dBu since that's the output level of the MixPre.I love how you completely ignored qap's question lol. Will a regular ol' XLR-F>XLR-M cable get the job done?
