TC
Resident Agitator
You'll have to excuse the length of this post- this has been on my mind and I've got a lot of thoughts floating around.
A friend recently told me her dictum when it comes to keeping a file- "if you don't have it in two separate places, you don't have it."
Meaning that if you've only got one copy of a file on one harddrive then you should assume that it is going to crash and totally wipe you out. I thought this was a good way of thinking about it.
What do you guys do about preserving your files?
I used to burn segmented DVDs, but realizing the shelf life of most run-of-the-mill DVDs, this doesn't seem viable. (Some of my earliest ripped DVDs are already starting to fail). Plus it's a pain to pull a single file from a .rar that is spread out over 5 DVDs.
When I built my last computer I intended it to run RAID 5, but XP Home doesn't support it- so I'm left with almost 1TB of storage space inside my computer, with no fail safe.
Here's the scary part- I'm almost full up! Yikes!
What I'm thinking about doing is installing a hot-swap SATA bay, and I already have an IDE bay that I can use as well. Then just picking up whatever harddrives are on sale at Fry's that particular week and backing up 2 drives with the exact same contents.
Thoughts? I know it seems a bit costly and redundant, but with harddrive prices going way, WAY down it seems like the best solution.
