How do I use focus assist with a C-Mount Lens?
majikfraug
Is there a way to use the focus assist feature while shooting with a manual lens?
It pops on automatically when I use my micro 4/3 lenses in manual focus mode, but how do I get it to pop on when I'm using my c-mount lens?
Press left keypad button - yellow square in frame - press middle button - Violà! - zoomed in.
Before pressing middle you can move around the square with the outer keypad buttons to chose what part of picture you zoom in on and you can also move around when already zoomed in.
you have to do it manually as martti said. there is no electronic communication from the lens to tell the body that you are trying to focus so it wont auto assist you.
Actually I got annoyed of the focus assist popping on by itself as soon as I turned the focus ring when using the kit lens. I disabled the auto function and enable focus assist manually when I need it.
Same, the kit lens focus wheel felt so sensitive (to me) that when I wasn't trying to focus it was kicking in the focus assist. I turned it off and enjoy the control of the d-pad.
Thank you all so much! I knew there was a simple solution -and that someone on here knew what it was. I don't have the kit lens BTW, but my friend does and I must say I am very impressed with it.
I'd like the GH to jump to focus assist when i say.. half press the shutter button. You think there's any way of doing this? The 2 button way is a bit of a hassle...Guess i'll just have to do it enough so I don't have to think about it anymore.
It took me a while to figure this one out as well... when using my manual lenses I just assumed the focus assist did not work. Then somebody told me otherwise and I went digging through the menu's everywhere, thinking I had to assign it to the function button or something like that. I didn't realise that all along it had it's own dedicated button on the d-pad!
