How do I insert pictures?
Re: How do I insert pictures?
If you are ineterested in posting frame grabs then read this thread:
http://www.dvxuser.com/cgi-bin/DVX2/YaBB.pl?board=Clips;action=display;num=1085960689
Otherwise, if you would like to insert an image into a post, then use the "img" tags. For example:
[ img ]http://the/url/to/your/image.jpg[ /img ]
Note, the spaces around the "img" tag are necessary in this example only so the tag shows up literally. Do not include them when using the tag to insert an image.
You can click the image tag button
above the comment form to insert these tags for you. Then insert your URL between the tags.
