How do I export Chroma Keying work?
Amadou
Carbonite Member
I just did some Chroma Keying in AE 5.5 using Keylight. The two AVI files I used as forground and background are Cineform NEO codec AVI files (1920 X1080). Now I need to put the work back on the Premiere Timeline. I can't.
There is no way to export in Cineform codec (or any other codec of my choosing).
When saving the work into a Premiere project from AE, I simply can't open it in Premiere as it tells me Premiere can't handle Keylight.
Since I can neither export an AVI nor transfer with a project, how am I supposed to use whatever work I do in AE?
PS: I don't have the Production Suite. Just AE CS5 and Premiere CS5. So how do I go back and forth between the two? Thank you.
I only get three export options:
Adobe Flash Player
Adobe Flash Player Professional
Adobe Premiere
If I export to Adobe Premiere it will create a premiere project file which premiere won't be able to open as Premiere will say it does not have the Keylight plug in.
Composition > Add to Render Queue
That will open up your render queue window where you can customize your output formats/destination.
